Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 8
Carefully align the exposed portion of the adhesive strips along the edge of the front of the battery, and press them gently into place. Some devices need to have the battery pull tabs located near the top of the device, and some have them located near the bottom. Evaluate what will work for your repair. Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and realigned.
  • Carefully align the exposed portion of the adhesive strips along the edge of the front of the battery, and press them gently into place.
  • Some devices need to have the battery pull tabs located near the top of the device, and some have them located near the bottom. Evaluate what will work for your repair.
  • Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and realigned.
Richte den freiliegenden Abschnitt der Klebestreifen an der Kante auf der Vorderseite des Akkus aus und drücke sie sorgfältig fest.
Bei manchen Geräten müssen sich die Akku-Zuglaschen oben am Gerät befinden, bei anderen unten. Entscheide, wie es in deinem Fall sein muss.
Achte darauf, die Klebestreifen gleich beim ersten Mal korrekt auszurichten. Wenn sie einmal am Akku festkleben, können sie nicht mehr abgelöst und erneut ausgerichtet werden.
