Zum Hauptinhalt wechseln
Apple Watch Series 6 배터리 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 2
Apple Watch Series 6 Battery Replacement, Determine which procedure to follow: Schritt 0, Bild 1 von 1
  • From this point, the battery removal procedure for the 40 mm watch differs slightly from the 44 mm version.
  • If you're replacing the battery for a 40 mm watch, continue with this step.
  • If you're replacing the battery for a 44 mm watch, continue with this step.
이 시점부터, 40mm 시계의 배터리 분리 절차는 44mm 버전과 약간 다릅니다.
40mm 시계의 배터리를 교체하는 경우 이 단계로 진행하세요.
44mm 시계의 배터리를 교체하는 경우 이 단계로 진행하세요.
[title] Determine which procedure to follow
[* icon_note] From this point, the battery removal procedure for the 40 mm watch differs slightly from the 44 mm version.
- [* red] If you're replacing the battery for a 40 mm watch, continue with [guide|137588|this step|stepid=286360].
- [* orange] If you're replacing the battery for a 44 mm watch, continue with [guide|137588|this step|stepid=275039].
+ [* red] If you're replacing the battery for a 40 mm watch, continue with [guide|137587|this step|stepid=286360].
+ [* orange] If you're replacing the battery for a 44 mm watch, continue with [guide|137587|this step|stepid=275039].
