Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 9
Beneath the battery, stretch release adhesive just where we expect it, like a familiar tune on your drive to work. The 12 and 12 Pro have four tabs each, and they perform as expected. One thing that could stand to change, though: the tiny, flimsy pull-tab "starter" section Apple provides. What are these, pull tabs for ants? We've heard through the applevine that the 12 and 12 Pro are using the exact same battery. With that said (puts on examination glasses) yup! We see 10.78 Wh for both batteries.
  • Beneath the battery, stretch release adhesive just where we expect it, like a familiar tune on your drive to work. The 12 and 12 Pro have four tabs each, and they perform as expected.
  • One thing that could stand to change, though: the tiny, flimsy pull-tab "starter" section Apple provides. What are these, pull tabs for ants?
  • We've heard through the applevine that the 12 and 12 Pro are using the exact same battery. With that said (puts on examination glasses) yup! We see 10.78 Wh for both batteries.
  • They are also interchangeable in our parts swap tests.
  • This is a marked decrease from the 11 and 11 Pro, which ring in at 11.91 Wh and 11.67 Wh, respectively. But the highly efficient new 5nm-process A14 chip might be making up for that difference: as per Apple's official specs, battery life doesn't suffer at all.
  • It's a bit disappointing to see Apple back away from the unique L-shaped battery designs it developed for recent iPhones. Rumors pointed to Apple using cheaper parts to offset the cost of 5G, and this seemingly bears that out.
Unter dem Akku finden wir elastische Klebestreifen , die uns so vertraut sind wie unsere Werkzeugtasche. Das 12 und das 12 Pro haben jeweils vier Laschen und sie funktionieren erwartungsgemäß.
Eines könnte allerdings durchaus verbessert werden: die mickrigen dünnen Abschnitte, die Apple als "Starter"laschen einsetzt. Sollen das Zuglaschen für Ameisen sein?
Angeblich soll im 12 und im 12 Pro der exakt gleiche Akku verbaut sein. Wir setzen mal kurz unsere Brillen auf. Stimmt: Beide Akkus verfügen über 10,78 Wh.
Bei unserem Teile-Test, waren sie auch untereinander austauschbar.
Das ist eine deutliche Verringerung im Vergleich zum 11 und 11 Pro, die über 11,91 Wh und 11,67 Wh verfügen. Allerdings wird das wahrscheinlich durch den extrem effizienten neuen 5nm-process A14 Chip ausgeglichen: Laut den offiziellen Spezifikationen von Apple wird die Akku-Lebensdauer überhaupt nicht beeinträchtigt.
Es ist ein bisschen enttäuschend, dass sich Apple von den einzigartigen, L-förmigen Akku-Designs abgewendet hat, die sie für die letzten iPhones entwickelt hatten. Gerüchten zufolge, benutzt Apple günstigere Teile, um die Kosten für 5G wettzumachen, was das zu bestätigen scheint.
