Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 12
For our last trick, we'll attempt to remove this 88° curved 6.76" screen. Unlike Apple’s latest series of smartphones, Huawei didn't choose between 5G and a high refresh rate display—the Mate 40 Pro gets both! Making things even smoother, the display has a 240 Hz touch sampling rate. First, we treat the screen with copious amounts of heat. After several minutes of hard work, we manage to press our iMac Opening Wheel under the screen … only to watch the glass immediately shatter.
  • For our last trick, we'll attempt to remove this 88° curved 6.76" screen.
  • Unlike Apple’s latest series of smartphones, Huawei didn't choose between 5G and a high refresh rate display—the Mate 40 Pro gets both! Making things even smoother, the display has a 240 Hz touch sampling rate.
  • First, we treat the screen with copious amounts of heat. After several minutes of hard work, we manage to press our iMac Opening Wheel under the screen … only to watch the glass immediately shatter.
  • Our hunch is that Huawei may be using a stronger new adhesive for this Mate 40 Pro display. Even after more heat, the screen refuses to yield—no matter which tool we use, or what angle we attack.
  • We knew going into this that curved displays were a nightmare to remove, but even we were not prepared for how terrible this one would be. No thanks, Mate.
Als letztes versuchen wir, das 88° gekrümmte 6,76" Display herauszuholen.
Im Gegensatz zu Apples aktuellen iPhones hat Huawei sich nicht zwischen 5G und hoher Bildwiederholrate entschieden, sondern beides in das Mate 40 Pro gepackt. Zusätzlich hat das Display 240 Hz Berührungsabtastrate.
Erstmal bekommt das Display die Hitze, die es verdient. Nach ein paar Minuten harter Arbeit können wir das iMac Opening Wheel unter das Display schieben ... und gucken dann dem Glas zu, wie es sofort zerspringt.
Wir gehen davon aus, dass Huawei für dieses Display viel stärkeren Kleber verwendet. Aber selbst nach viel mehr Hitze löst sich das Display nicht - egal, welches Werkzeug in welchem Winkel wir ansetzen.
Wir wussten, dass gekrümmte Displays richtig schlecht zu ersetzen sind, aber wir waren wirklich nicht darauf vorbereitet, wie schlimm es diesmal werden würde. Darauf hätten wir verzichten können.
