Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire. Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp. Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
  • Use the plastic opening tool to push each side of the crimp away from each other. This will open the crimp holding the wire.
  • Use your fingers to lift the wire out of the crimp when there is enough separation between the sides of the crimp.
Hier Übersetzung einfügen
