Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Having dawdled enough, we dive into the Mi 11 and the rear glass magically flies off (perhaps with a bit of off-camera encouragement from our iOpener). If that looked a little too easy, keep in mind that (1) this phone bears no official IP rating, so you'll never know how well (or how poorly) it's protected against water or dust, and (2) if we ever developed actual magic tools, we would definitely share them with you. Probably. Our Moray Kit lends us a helping hand in loosening those Phillips screws and makes the removal of the wireless charging coil a breeze.
  • Having dawdled enough, we dive into the Mi 11 and the rear glass magically flies off (perhaps with a bit of off-camera encouragement from our iOpener).
  • If that looked a little too easy, keep in mind that (1) this phone bears no official IP rating, so you'll never know how well (or how poorly) it's protected against water or dust, and (2) if we ever developed actual magic tools, we would definitely share them with you. Probably.
  • Our Moray Kit lends us a helping hand in loosening those Phillips screws and makes the removal of the wireless charging coil a breeze.
  • We're mildly excited to find a motherboard layout similar to the one in the OnePlus Nord, which enables separate battery and display removals. (Fingers crossed the screen cable isn't running underneath the battery like in the Mate 40 Pro.)
Genug herumgetrödelt, jetzt geht's an das Innere des Mi 11. Die Rückabdeckung aus Glas hebt sich wie durch Magie ab (da wurde vielleicht in den Kulissen mit dem iOpener nachgeholfen).
Wenn das zu leicht aussah, dann darfst du zwei Punkte nicht vergessen: Erstens hat dieses Smartphone keine offizielle IP Bewertung, sodass du nie sicher weißt wie gut (oder schlecht) es gegen Wasser und Staub geschützt ist. Zweitens: Wenn wir je tatsächlich magische Werkzeuge entwickelten, würden wir sie euch auf jeden Fall zeigen. Eventuell.
Mit Hilfe unseres Moray Kits lösen wir die Kreuzschlitzschrauben und der Ausbau der kabellosen Ladespule ist damit das reinste Kinderspiel.
Wir sind angenehm überrascht, dass das Motherboard Layout ähnlich wie das des OnePlus Nord ist, was einen getrennten Austausch von Akku und Display ermöglicht. (Hoffentlich verläuft das Displaykabel nicht unter dem Akku wie im Mate 40 Pro.)
