Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 11
The AMOLED DotDisplay—one of the Mi 11's power eaters—shines with up to 120 Hz adaptive refresh rate and a WQHD+ resolution of 3200 x 1440 pixels (~515 ppi). It also packs a blistering 480 Hz touch sampling rate. Curved displays can create a novel "infinity edge" look, but they are usually a pain to remove. But with some encouragement from our iMac Opening Wheel, the display comes off splinter-free—should we thank the lack of an IP rating for that? The ultra-thin optical in-display fingerprint sensor by Goodix hides under the display and requires some gentle pulling to come free.
  • The AMOLED DotDisplay—one of the Mi 11's power eaters—shines with up to 120 Hz adaptive refresh rate and a WQHD+ resolution of 3200 x 1440 pixels (~515 ppi). It also packs a blistering 480 Hz touch sampling rate.
  • Curved displays can create a novel "infinity edge" look, but they are usually a pain to remove. But with some encouragement from our iMac Opening Wheel, the display comes off splinter-free—should we thank the lack of an IP rating for that?
  • The ultra-thin optical in-display fingerprint sensor by Goodix hides under the display and requires some gentle pulling to come free.
  • Lastly, we'll peel apart the Mi 11's vapor chamber cooling system, which combines with these multiple layers of graphite and AI to keep this machine cool. Copper and graphite are both very efficient at offloading heat, so we're not sure how much the AI actually contributes here—but sure, why not!
Das AMOLED DotDisplay, einer der Energiefresser des Mi 11, glänzt mit einer adaptiven Bildwiederholungsrate von bis zu 120 Hz und einer WQHD+ Auflösung von 3200 x 1440 Pixel (~515 ppi). Außerdem verfügt es über eine wahnsinnige 480 Hz Abtastrate.
Gebogene Displays geben zwar den neuartigen "Infinite Edge" Look, ihr Ausbau ist aber meistens ziemlich nervig. Unser iMac Opening Wheel hat ganze Überzeugungsarbeit geleistet, und das Display lässt sich ohne zu brechen entfernen. Sollte unser Dank vielleicht an die fehlende IP Bewertung gehen?
Unter dem Display versteckt sich der ultra-dünne optische In-Display Fingerabdrucksensor von Goodix, durch leichtes Ziehen können wir ihn ablösen.
Ganz zum Schluss nehmen wir das Vapor Chamber Kühlsystem des Mi 11 auseinander, dessen viele Graphitschichten zusammen mit AI das Gerät kühl halten. Sowohl Kupfer als auch Graphit sind sehr effizient, wenn es um Wärmeableitung geht, daher sind wir uns nicht so ganz sicher wie groß die Rolle von AI ist, aber, hey warum nicht!
