Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 5
The same large adhesive gasket holds both the back cover and camera bump in place—but the bump can be carved off separately, making for some interesting DIY customization possibilities. ... and, unlike the S20 Ultra, the glass camera lenses can be individually replaced—which is probably a good thing. With the back panel removed, we can gawk at how humongous this phone looks next to our tiny Minnow Driver Kit.
  • The same large adhesive gasket holds both the back cover and camera bump in place—but the bump can be carved off separately, making for some interesting DIY customization possibilities.
  • ... and, unlike the S20 Ultra, the glass camera lenses can be individually replaced—which is probably a good thing.
  • With the back panel removed, we can gawk at how humongous this phone looks next to our tiny Minnow Driver Kit.
  • The 'lil guy still gets the job done—proving it's not the size of the toolkit that matters, but how you use it.
  • The guts seem a slight iteration over last year's S20 Ultra, with minor changes to the wireless charging coil and upper antenna assemblies.
  • The earpiece speaker comes out with the antenna assembly this go-round, which is an updated design we first saw in the Note 20—as opposed to being separately adhered to the frame in prior phones like the S20 Ultra.
Die Rückabdeckung sowie die Kamerabeule sind mit der gleichen großen Klebedichtung befestigt, aber die Beule kann separat abgelöst werden, was ein paar interessante Möglichkeiten zur DIY Personalisierung bietet.
Und im Gegensatz zum S20 Ultra, können die Kameralinsen aus Glas einzeln ausgetauscht werden, was wahrscheinlich eine gute Sache ist.
Jetzt wo die Rückabdeckung weg ist, wird uns erst klar wie riesig dieses Smartphone neben unserem winzigen Minnow Driver Kit aussieht.
Dieses kleine Kerlchen leistet ganze Arbeit, was beweist, dass es nicht die Größe eines Toolkits ist, die zählt, sondern wie man es nutzt.
Von innen scheint sich seit dem S20 Ultra von letztem Jahr nur wenig getan zu haben, außer ein paar geringfügigen Änderungen an der kabellosen Ladespule und den oberen Antennenbaugruppen.
Dieses Mal kommt der Ohrhörer-Lautsprecher mit der Antennenbaugruppe heraus, es handelt sich hierbei um ein verbessertes Design, das wir zum ersten Mal beim Note 20 gesehen haben, im Gegensatz zu vorherigen Smartphones wie das S20 Ultra, bei dem er getrennt am Rahmen festgeklebt ist.
