Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 6
Peel up the two remaining battery adhesive pull-tabs to un-stick them from the top edge of the battery. There's not a lot of space to grab these adhesive strips—using an opening pick to separate them from the battery before grabbing them with tweezers may help. There's not a lot of space to grab these adhesive strips—using an opening pick to separate them from the battery before grabbing them with tweezers may help.
  • Peel up the two remaining battery adhesive pull-tabs to un-stick them from the top edge of the battery.
  • There's not a lot of space to grab these adhesive strips—using an opening pick to separate them from the battery before grabbing them with tweezers may help.
Löse die letzten beiden Zuglaschen der Klebestreifen von der Oberkante des Akkus ab.
Diese Klebestreifen sind kaum zu greifen. Es könnte helfen, wenn du sie vorher mit einem Plektrum vom Akku löst und sie dann mit einer Pinzette herausziehst.
