Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 10 übersetzen
Schritt 10
Lift out the motherboard
Carefully guide the joysticks through the front case and lift the motherboard out.
The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
[title] Lift out the motherboard | |
[* black] Carefully guide the joysticks through the front case and lift the motherboard out. | |
+ | [* black] The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints. |
[* icon_caution] ***Do not completely remove the motherboard.*** There are four soldered wires tethering the motherboard to the vibrator motors. |
