Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Place the lamp horizontally on a work surface
Disassemble
  • Place the lamp horizontally on a work surface
  • Unscrew the two screws above the control panel that hold the upper and lower parts of the lamp together
  • Slide up the control panel to remove
  • Unscrew the two screws that hold the power board in place
  • Use a soldering iron to gently melt the two plastic studs that hold the touch sensor circuit board in place
  • Remove the touch sensor button. It's not really an electrical or mechanical button; it's just decorative.
  • Install a small fender washer, machine screw and nut. Drill a small hole in the center of the control panel where the touch sensor button is placed.
  • Drill out the bottom plastic stud for the touch sensor circuit board mount.
Hier Übersetzung einfügen
