Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Lay down the case so that the power button is on the far top right corner and is facing your right. Remove the top panel by first pushing its ridgeline away from you. Once this is done, you should be able to slide the panel off of the case. Remove the side panel facing you, first push its ridgeline away from you. Once this is completed, you should be able to lift the panel off of the case.
  • Lay down the case so that the power button is on the far top right corner and is facing your right.
  • Remove the top panel by first pushing its ridgeline away from you. Once this is done, you should be able to slide the panel off of the case.
  • Remove the side panel facing you, first push its ridgeline away from you. Once this is completed, you should be able to lift the panel off of the case.
Hier Übersetzung einfügen
