Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 13
Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it. Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
  • Use the flat end of a spudger to pry the display cable connector straight off of the antenna board to disconnect it.
Heble den Stecker des Displaykabels mit dem flachen Ende des Spudgers gerade nach oben und trenne ihn von der Antennenplatine ab.
