Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Insert the tip of an opening pick in the gap between the midframe and the screen, next to the iFlex. Remove the iFlex. Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
Insert an opening pick
  • Insert the tip of an opening pick in the gap between the midframe and the screen, next to the iFlex.
  • Remove the iFlex.
  • Slide the opening pick to the bottom right corner to cut the adhesive. Leave it in its place to prevent the adhesive from resealing.
Setze die Spitze eines Plektrums in den Spalt zwischen Rahmen und Display, neben das iFlex.
Entferne das iFlex.
Führe die Spitze des Plektrums zur unteren rechten Ecke und schneide durch den Kleber. Lass es dort stecken, damit sich der Kleber nicht wieder verbindet.
