Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver. During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
  • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
Entferne die acht Y1 Tri-Wing Schrauben von der Gehäuserückseite.
Halte beim Zusammenbau die Gehäuseteile fest zusammen, während du die Schrauben hineindrehst.
-[* black] Remove the eight 9-mm Tri-Wing screws on the back panel with the Tri-wing Y1 screwdriver.
-[* icon_note] During reassembly, firmly hold the panels of the controller together while replacing screws so the panels don't separate.
+[* red] Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
+[* icon_reminder] During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
