Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 17 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery. Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Battery connector information
  • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
  • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
Diese Fotos zeigen, wie der Akkustecker unter dem Logic Board aussieht. Nutze die Fotos zur Information, um den Stecker sicher zu lösen.
Beachte, dass der Akkustecker mit freien (Cantilever-) Federn auf dem Logic Board gegen die Kontaktflächen gedrückt wird. Da sowohl das Logic Board, als auch der Akku festgeklebt sind, benötigst du ein dünnes und flexibles Werkzeug, das zwischen die Kontaktflächen gleiten kann.
