Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 4
The battery press connector is attached to the underside of the display cable bracket on the screw hole side. Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
Disconnect the battery
  • The battery press connector is attached to the underside of the display cable bracket on the screw hole side.
  • Insert the flat end of a spudger under the display cable bracket and lift up to disconnect the battery press connector from the logic board.
  • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
  • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  • Don't try to remove the display cable bracket as it's attached to the battery by the battery cable.
Hier Übersetzung einfügen
