Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
The display cable bracket is secured by a clip under the edge of the frame. Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge. Rotate the display cable bracket toward the battery.
  • The display cable bracket is secured by a clip under the edge of the frame.
  • Use a pair of tweezers to pull the display cable bracket's clip out from under the frame's edge.
  • Rotate the display cable bracket toward the battery.
  • Don't bend the battery cable too much past vertical to avoid damaging it. You only need enough space to disconnect the display press connectors and prevent the battery connector from making contact with its socket during the repair.
Hier Übersetzung einfügen
