Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Use a pair of tweezers to lift and remove the rear facing camera.
Remove the rear facing camera
  • Use a pair of tweezers to lift and remove the rear facing camera.
  • If you are going to reuse the original rear facing camera, take care not to damage the lens or the ribbon cable adhered to its sides.
  • If there's any alcohol solution remaining in the device, carefully wipe it off or allow it to air dry before installing your new rear facing camera.
  • During reassembly, remove any remaining adhesive and residue before applying new adhesive and installing the rear facing camera.
  • Follow this guide if you are using a pre-cut adhesive.
  • Follow this guide if you are using custom-cut adhesives for your device.
Hier Übersetzung einfügen
