Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Be careful not to use too much force or you might break the plastic rings holding the side panels in place. Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
  • Be careful not to use too much force or you might break the plastic rings holding the side panels in place.
  • Lift up the bottom cover. Pull the side panel up first, out, and away from the device.
  • The side panels have plastic rings that will need to be lifted up and off the cylinders they are placed around.
Hier Übersetzung einfügen
