Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device. Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
  • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
  • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
Hier Übersetzung einfügen
