Zum Hauptinhalt wechseln
Frontpanel-Baugruppe
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 16 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 7 übersetzen
Englisch
Deutsch
Schritt 7
Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 1 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 2 von 3 Front Panel Assembly Removal, Remove the front panel assembly: Schritt 0, Bild 3 von 3
  • Remove the front panel assembly.
  • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
  • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
  • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
  • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
  • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
  • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
Entferne die Frontpanel-Baugruppe.
Trenne mit einem Plektrum eventuell noch vorhandene Kleberreste zwischen der Frontpanel-Baugruppe und dem Rahmen auf.
Wenn bei deinem Display Probleme mit Phantomeingaben auftreten, kannst du diese mit einer Schicht von ganz dünnem Klebeband wie Kapton(Polyimid-) band an den markierten Stellen auf der Rückseite des Panels beseitigen. Ersatztouchscreens von iFixit sind schon entsprechend isoliert und benötigen keine weitere Behandlung.
Ohne geeignete Isolation können manche Bereiche des Touchscreens Kontakt zu anderen Bauteilen haben. Dadurch können Störungen bei Touch-Eingaben entstehen.
Die Isolierung ist nicht leicht zu erkennen und unterscheidet sich von den Schaumstoffstreifen bei anderen iPads, die gegen das Eindringen von Staub schützen sollen.
Bevor du das Display beim Zusammenbau wieder einbaust musst du Kleberreste vom iPad beseitigen. Reinige dann die Klebestellen mit hochkonzentrierten Isopropylakohol (mindestens 90%ig) und einem fusselfreien Tuch. So wird das iPad für die neuen Klebestreifen vorbereitet und der Kleber kann besser haften.
Bevor du das iPad wieder zuklebst, solltest du es zuerst testen und und vorgestanzte Klebestreifen auf der Rückseite des Displays anbringen. Verwende dazu unsere Anleitung zum Ankleben des Displays.
