Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 2
Start removing the 13mm bolts from the coil rail. Use an extension will make it easier to clear the radiator hoses and throttle cables. Use a smaller extension to remove the 4th bolt in the back of the rail. All 4 bolts are identical in size and need not to be separated.
  • Start removing the 13mm bolts from the coil rail. Use an extension will make it easier to clear the radiator hoses and throttle cables.
  • Use a smaller extension to remove the 4th bolt in the back of the rail.
  • All 4 bolts are identical in size and need not to be separated.
Hier Übersetzung einfügen
