Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
With all 4 bolts removed, the rail should easily pull off the spark plugs.  One electrical connector (located at the rear end of the coil rail) is used for all three coils. It is not necessary to totally remove the rail for a spark plug change. Rubber boots seal the secondary terminal ends of the coils to the top of all 6 spark plugs. Use a 5/8inch spark plug socket and extension to remove the spark plug. Again, the ignition rail can be easily moved out of the way.
  • With all 4 bolts removed, the rail should easily pull off the spark plugs. One electrical connector (located at the rear end of the coil rail) is used for all three coils. It is not necessary to totally remove the rail for a spark plug change.
  • Rubber boots seal the secondary terminal ends of the coils to the top of all 6 spark plugs.
  • Use a 5/8inch spark plug socket and extension to remove the spark plug. Again, the ignition rail can be easily moved out of the way.
Hier Übersetzung einfügen
