Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 47 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3 übersetzen
Schritt 3
During reassembly, gently push down the center of the lower case to reattach the two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips.
  • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  • The lower case is connected to the upper case at the center, with two plastic clips.
Das untere Gehäuse ist in der Mitte durch zwei Plastikklammern mit dem oberen Gehäuse verbunden.
Drücke beim Wiederzusammenbau das untere Gehäuse in der Mitte leicht an, damit die beiden Plastikklammern wieder einrasten.
-[* icon_note] The lower case is connected to the upper case at the center, with two plastic clips.
[* icon_reminder] During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
+ [* red] The lower case is connected to the upper case at the center, with two plastic clips.
