Zum Hauptinhalt wechseln
MacBook Air 2022 (M2) Screen Replacement
Englisch
Koreanisch
Schritt 7
MacBook Air 2022 (M2) Screen Replacement: Schritt 0, Bild 1 von 3 MacBook Air 2022 (M2) Screen Replacement: Schritt 0, Bild 2 von 3 MacBook Air 2022 (M2) Screen Replacement: Schritt 0, Bild 3 von 3
  • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
  • Lift straight up to disconnect the cable.
  • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
  • Repeat for the second antenna cable.
  • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
Hier Übersetzung einfügen
