Zum Hauptinhalt wechseln
Microsoft Surface Laptop 4 (15-inch) Battery Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
Microsoft Surface Laptop 4 (15-inch) Battery Replacement, Separate the battery contact cable: Schritt 0, Bild 1 von 3 Microsoft Surface Laptop 4 (15-inch) Battery Replacement, Separate the battery contact cable: Schritt 0, Bild 2 von 3 Microsoft Surface Laptop 4 (15-inch) Battery Replacement, Separate the battery contact cable: Schritt 0, Bild 3 von 3
  • Slide an opening pick under the battery cable and pry up to separate it from the frame.
  • If the adhesive is stubborn, don't force the pick. Reheat the cable and try again.
  • During reassembly:
  • If your battery cable has a plastic liner, remove it. Otherwise, apply double-sided tape to the underside of the cable.
  • Line up the cable with its screw post and alignment peg, and press down to secure the cable to the frame.
Hier Übersetzung einfügen
