Zum Hauptinhalt wechseln
Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4
Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Unclip the left motherboard shield: Schritt 0, Bild 1 von 3 Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Unclip the left motherboard shield: Schritt 0, Bild 2 von 3 Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Unclip the left motherboard shield: Schritt 0, Bild 3 von 3
  • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
  • Insert one arm of your tweezers under the corner of the left touchpad shield.
  • Gently pry up to release the clips securing the shield.
  • Try not to deform the shield too much. You'll need to reinstall it during reassembly.
  • Repeat this process around the perimeter of the shield until you can remove it.
Hier Übersetzung einfügen
