Zum Hauptinhalt wechseln
Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 11 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 20
Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Pry the left edge: Schritt 0, Bild 1 von 3 Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Pry the left edge: Schritt 0, Bild 2 von 3 Microsoft Surface Laptop 4 (15-inch) Motherboard Replacement, Pry the left edge: Schritt 0, Bild 3 von 3
Pry the left edge
  • A tab on the upper left of the motherboard presses against protrusions in the frame, preventing the left edge from coming free.
  • Insert the tip of a spudger against the tab in the upper left corner of the motherboard. Wedge the spudger between the frame and the screen hinge.
  • Pry up on the tab with your spudger while you lift the right edge of the motherboard toward the front of the laptop.
  • If the motherboard can't lift over the left speaker, the tab may still be stuck. Change the angle of your spudger and try again.
Hier Übersetzung einfügen
