Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working. Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
  • Verify that the console is disconnected from the AC outlet before you begin. If you have just powered off the system, give the capacitors a few minutes to discharge before you begin working.
  • Remove the white female pin header by clamping the clip and pulling it up gently from the power board.
Hier Übersetzung einfügen
