Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 30 übersetzen
Schritt 30
Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly. Once the display assembly is loosened from the front panel, it will fall away.
  • Blast the front panel with heat and pry between the display assembly and front panel bezel, working one or several guitar picks around the display assembly.
  • Once the display assembly is loosened from the front panel, it will fall away.
  • The front glass came off easily, but the digitizer was much more difficult to remove. The adhesive holding together the display assembly is much weaker than the adhesive holding the display assembly to the front panel.
  • While creating this guide, I utterly destroyed the front panel bezel and digitizer. Replacing the display assembly was a breeze--but removing the digitizer required nearly a dozen reheats of the front panel. To replace the bezel, you will need a new "mid chassis" (that's the front panel piece the digitizer is so powerfully glued to).
Hier Übersetzung einfügen
