Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
Use the tip of a hobby knife or plastic opening tool to pry the button assembly off of the adhesive securing it to the display assembly. Keep the sharp edge of the knife pointed away from the cable to avoid accidentally cutting it. Keep the sharp edge of the knife pointed away from the cable to avoid accidentally cutting it.
  • Use the tip of a hobby knife or plastic opening tool to pry the button assembly off of the adhesive securing it to the display assembly.
  • Keep the sharp edge of the knife pointed away from the cable to avoid accidentally cutting it.
Benutze die Spitze eines Skalpells, um die Tastengruppe aus der Klebeverbindung zur Displayeinheit zu lösen.
Halte die scharfe Kante des Skalpells weg vom Kabel, um es nicht versehentlich durchzuschneiden.
-[* black] Use the tip of a hobby knife to pry the button assembly off of the adhesive securing it to the display assembly.
+[* black] Use the tip of a hobby knife or plastic opening tool to pry the button assembly off of the adhesive securing it to the display assembly.
[* icon_caution] Keep the sharp edge of the knife pointed away from the cable to avoid accidentally cutting it.
