Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 41 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched. Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. During reassembly, connect this end first as it does not flex.
  • If your I/O Board cable's connectors have notches in the padding, you will need to release a locking lever underneath the notch in order to remove the cable. If this is the case, don't pry up on the connector until the levers are unlatched.
  • Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
  • During reassembly, connect this end first as it does not flex.
  • In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
  • Remove the I/O Board cable from the MacBook Pro.
Heble den Stecker des I/O-Boards mit dem flachen Ende eines Spudgers aus seiner Buchse auf dem Logic Board heraus. Beim Zusammenbau zuerst dieses Ende verbinden, da es sich nicht biegt.
Entferne auf die gleiche Weise den I/O-Board-Stecker von seiner Buchse auf dem I/O-Board.
Entferne das I/O-Board Kabel vom MacBook Pro.
-[* black] Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board. On reassembly, connect this end first as it does not flex.
+[* icon_note] If your I/O Board cable's connectors have [link|https://guide-images.cdn.ifixit.com/igi/NcprwYqAITaNGRVg.full|notches in the padding], you will need to ***release a locking lever underneath the notch*** in order to remove the cable. If this is the case, ***don't pry up on the connector until the levers are unlatched***.
+[* black] Using the flat end of a spudger, pry the I/O Board connector straight up out of its socket on the logic board.
+ [* icon_reminder] During reassembly, connect this end first as it does not flex.
[* black] In a similar fashion, remove the I/O Board connector from its socket on the I/O Board.
[* black] Remove the I/O Board cable from the MacBook Pro.
