Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 48 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Flip up the retaining flap on the LCD ribbon cable ZIF connector. Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board. You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
  • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
  • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
  • You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
Klappe die Haltelasche über dem ZIF Stecker des LCD Flachbandkabels hoch.
Löse mit den Händen oder eine Pinzette das LCD Flachbandkabel von seiner Fassung auf dem Logic Board.
[* black] Flip up the retaining flap on the LCD ribbon cable ZIF connector.
[* black] Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
[* icon_reminder] You may have to force restart the iPad by holding down the power button and home button for at least ten seconds until you see the Apple logo if the LCD screen doesn't power on after connecting the ZIF connector for the LCD screen when putting everything back together.
