Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 6 übersetzen
Schritt 6
Insert the tip of a spudger into the opening located near the top right corner of the microphone assembly. Carefully pry the spudger upwards against the rear case to dislodge the microphone assembly from the adhesive securing it to the rear case. Lift and remove the microphone assembly from the iPad.
  • Insert the tip of a spudger into the opening located near the top right corner of the microphone assembly.
  • Carefully pry the spudger upwards against the rear case to dislodge the microphone assembly from the adhesive securing it to the rear case.
  • Lift and remove the microphone assembly from the iPad.
Setze die Spitze eines Spudgers in die Öffnung in der Nähe der oberen rechten Ecke der Mikrofoneinheit.
Drücke den Spudger vorsichtig gegen das Rückgehäuse hoch, um so die Mikrofoneinheit von der Klebeverbindung zum Rückgehäuse zu lösen.
Hebe die Mikrofoneinheit hoch und entferne sie aus dem iPad.
