Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Place the bottom of the tablet towards you. Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
  • Place the bottom of the tablet towards you.
  • Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
  • If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
  • On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
Drehe die Unterseite nach oben.
Drehe die zwei 4,1 mm Schrauben bei der Ladebuchse mit einem Tri-Wing Schrauber heraus.
[* black] Place the bottom of the tablet towards you.
-[* red] Remove the two 4.1 mm screws near the charge port with a Tri-Wing screwdriver.
+[* red] Remove the 4.1mm screws near the charge port with a Tri-Wing screwdriver.
+ [* black] If there are plastic tabs covering these screws, use pointed tweezers to pry the tabs out.
+ [* icon_note] On model GT-P7500, this step is omitted, as that model doesn't have these 2 screws.
