Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 6 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 2
Loosen the two 6.35 mm size 1 Phillips screws on the back cover. The two screws are spring loaded and will not separate from the cover. Slide the back cover towards you and then  lift upwards to remove.
  • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
  • The two screws are spring loaded and will not separate from the cover.
  • Slide the back cover towards you and then lift upwards to remove.
Hier Übersetzung einfügen
