Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 11
Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad. The screen and the front panel is connected by a black tape that could rip if not removed carefully. You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
  • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
  • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
  • You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
Hebe das LCD mit einem Spudger aus dem Vorderteil. Setze den Spudger direkt in den Spalt links vom Steuerkreuz.
Der Bildschirm und das Vorderteil sind mit einem schwarzen Band verklebt. Du musst es sorgfältig entfernen sonst reißt es.
[* black] Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
[* icon_caution] The screen and the front panel is connected by a black tape that could rip if not removed carefully.
[* icon_note] You can use an iOpener or a hair dryer on the other side of the front panel in order to soften the black tape.
