Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 17
While you’re sewing, remove the pins as you come to them. Running them over with your machine may break your needle. While you’re sewing, remove the pins as you come to them. Running them over with your machine may break your needle. While you’re sewing, remove the pins as you come to them. Running them over with your machine may break your needle.
  • While you’re sewing, remove the pins as you come to them. Running them over with your machine may break your needle.
Beim Nähen die Nadeln entfernen, bevor Sie sie erreichen. Wenn man mit der Maschine über Stecknadeln näht, kann die Nähnadel abbrechen.
