Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 3
Pull the cooling/processing unit straight up to prevent damage to logic board
  • Pull the cooling/processing unit straight up to prevent damage to logic board
  • This will require some effort and should be done with caution to avoid damage.
  • The sleeves around the 6 screws may hold it in, if so just take a pair of needle nose pliers and gently squeeze the sleeves until it releases.
  • Pull the bottom, then side towards the bottom of the CPU case, first to move around the bottom coolant sleeve around the heat sinking bracket. *heat sinking bracket not in picture*
Hier Übersetzung einfügen
