Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Englisch
Deutsch
Schritt 11
  • Now heat the component lead. Then line it up so it is perpendicular to the crack and equally spaced on both sides of the crack.
  • Melt it evenly and gently into the gear across the crack. Try to only press it in 1-2mm, so most of it is beyond the edge of the gear, but don't push it in too far that it touches the shaft.
  • Let it cool for 3-5 seconds and then move. Moving beforehand may weaken the bond between the metal and plastic.
  • Necessary note: This is an art and may take time to get right, I highly suggest practicing with other plastic pieces you care less about first. Plan your attempts first. Its not quite a do or die thing, but you will start to render the plastic useless if you do not properly insert the lead.
Hier Übersetzung einfügen
