Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 3
Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break. After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side. After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
  • Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
  • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
Hier Übersetzung einfügen
