Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 3
This can be resolved by inserting a screw driver and gently forcing the slot into sight. Next a pair of either combination or slip joint pliers are needed to hold the gear, To remove the blade gear, turn the Magic Bullet on its side and use a flat tip screw driver on the bottom end, and the pliers on the base gear. Turn the blade gear in clock wise direction to remove it off the shaft.
  • This can be resolved by inserting a screw driver and gently forcing the slot into sight.
  • Next a pair of either combination or slip joint pliers are needed to hold the gear,
  • To remove the blade gear, turn the Magic Bullet on its side and use a flat tip screw driver on the bottom end, and the pliers on the base gear. Turn the blade gear in clock wise direction to remove it off the shaft.
  • The blade gear has a left-hand thread, which is opposite to the normal screw thread. So it will loosen when you turn clock-wise.
  • You may find it easier to remove the blade gear after the motor assembly has been removed from the body in Step 8.
  • If the blade gear refuses to budge, give it several sharp taps with a small ball end hammer directed at the center of the boss.
  • Note that the blade gear needs to be removed only if it is to be changed.
Hier Übersetzung einfügen
