Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 7
With the screws removed, lift the base of the body. Remove the wire mount out of the base and guide the electrical wire through the base. For this teardown, the fan blade on the motor shaft was removed. Remove the snap ring by inserting the corner of a flat tip screw driver. Simply twist the screw driver so that the snap ring will come away from the shaft.
  • With the screws removed, lift the base of the body. Remove the wire mount out of the base and guide the electrical wire through the base.
  • For this teardown, the fan blade on the motor shaft was removed. Remove the snap ring by inserting the corner of a flat tip screw driver.
  • Simply twist the screw driver so that the snap ring will come away from the shaft.
Hier Übersetzung einfügen
