Zum Hauptinhalt wechseln
Englisch
Deutsch
Schritt 10
Here is the motor removed from the base. The motor plate list it as D.S.D. Motor Co. LTD Model 5443/125 M12 There are two single-pole, Subminiature Micro Switches Marking on those is: Donghai KW4-3Z-3 5A 250VAC There is a thermal fuse wrapped to one of the switches leads.
  • Here is the motor removed from the base. The motor plate list it as D.S.D. Motor Co. LTD Model 5443/125 M12
  • There are two single-pole, Subminiature Micro Switches Marking on those is: Donghai KW4-3Z-3 5A 250VAC
  • There is a thermal fuse wrapped to one of the switches leads.
  • Remove the metal tie strap as well as the rubber sleeve to get to the fuse.
  • Here is the thermal fuse. It is a Avertronics 17AMC 105deg Thermal protector.
Hier Übersetzung einfügen
