Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone. Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside. Note: This will reveal a screw. Five screws should now be visible.
  • Insert a Spudger (or pushpin) into the top notch of the rubber cover, located on the top of the phone.
  • Press down and rotate the Spudger lifting the rubber cover. Remove and set cover aside.
  • Note: This will reveal a screw. Five screws should now be visible.
  • Using a T6 Torx screwdriver, unscrew all 5 screws and carefully set them aside.
Hier Übersetzung einfügen
