Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 40 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 2
Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board. Pull the AirPort card parallel out of its connector on the logic board to remove it.
  • Grasp the sides of the AirPort card and lift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board.
  • Pull the AirPort card parallel out of its connector on the logic board to remove it.
Greife die AirPort Karte an den dünnen Seiten und ziehe sie parallel zum Logic Board, um sie aus dem MacBook Pro zu entfernen.
[* black] Grasp the thin sides of the AirPort card and pull parallellift it up to a shallow angle (5-10˚) to separate the light adhesive adhering it to the logic board, removingboard.
[* black] Pull
the AirPort card fromparallel out of its connector on the MacBook Prologic board to remove it.
[* black] Pull
