Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
Loosen the two Phillips #00 screws that are securing the hard drive compartment. The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely. Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
  • Loosen the two Phillips #00 screws that are securing the hard drive compartment.
  • The screws are permanently attached to the hard drive compartment cover. Do not try to remove them completely.
  • Once the screws are sufficiently loosened, disconnect the clips holding the cover in place and slowly pull the cover away from the plastic chassis.
Hier Übersetzung einfügen
