Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 3
To begin actual removal of the battery itself, remove the four designated screws with your screwdriver. Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out. Once the battery is removed, it should look as it does in the third picture.
  • To begin actual removal of the battery itself, remove the four designated screws with your screwdriver.
  • Once the screws are removed, use either the tip of your screwdriver or a pair of tweezers to pull up the battery connector. Pull directly up and the connector should pop out.
  • Once the battery is removed, it should look as it does in the third picture.
Hier Übersetzung einfügen
