Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 7 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 5
Pry the opening tool into the slit between the two plastic sides of the device to separate the back panel from the front panel. Slide the opening tool across the slit until you are left with two, separated front and back panels.
  • Pry the opening tool into the slit between the two plastic sides of the device to separate the back panel from the front panel.
  • Slide the opening tool across the slit until you are left with two, separated front and back panels.
Hier Übersetzung einfügen
